MechanicalNetworks
This project serves as a toy example to showcase a TDD workflow and various approaches to design. For this reason we also setup project on gitlab including CI/CD pipelines, verifying various aspects of the code.
The framework computes effective stiffness of mechanical "circuits" (0D/1D networks) composed from set of linear spring with anisotropic stiffness linked in series and parallel. In particular, springs linked in parallel have effective stiffness given by
while in series
We provide couple essential components:
libMechanicalNetworks.so
providing all essential methods to link it in, see documentation.cmake
package to simplify linking to 3rd party projectsstiffness
interface able to evaluate theThe library and executable alone depend only on standard library, standard compilers (tested g++
and clang++
). However if optional components are enabled, they require further dependencies. In particular, we use GoogleTest for unit testing (libgtest-dev
on Debian based OS), Doxygen for generating documentation (packaged doxygen
, doxygen-latex
, graphviz
, dia
on Debian) and valgrind
for memory leak checks. Furthermore if code coverage is required, also gcovr
is required.
To simplify the dependency dealing for users we also provide a dedicated docker image with all dependencies prepared (see also registries ).
We recommend to have build folder outside of the source code, e.g.
This prevents pollution of source from build files and simplifies .gitignore
Basic build then use cmake
, in case of hierarchy above, it can look as something like:
Where last command allow us to install the library and Note that we refer to CMake
folder inside source. We intentionally separated build system from the code in case it needs to be replaced.
In case unit tests are requested they have to be enabled first, the full set of commands then look like:
This will compile also tests, which will be located inside folder build/Testing/MechanicalNetworks
. Either individual executables can be run or we can invoke from build
folder ctest .
to run them all:
Tests themselves are scattered across the source code in */Tests/*
folders. Note that unit tests cover more tests and functionality then tests for binary found in source/CLI/Tests
as they have much better access to all aspects.
Lastly one can also generate documentation by
which will generate HTML documentation inside build/Documentation
folder. Documentation can also be found online with all methods documented.
In case you decided to use provided docker image for build, it's recommended to bind the source only as read-only.
There are 3 supported ways how to use the project:
This is simplest case, binary reads line by line from standard input and for each line computes it's equivalent stiffness which prints to standard output. If there is an invalid/incomplete or otherwise faulty input. Program can be terminated by closing the standard input (e.g. Ctrl+D
on Linux). Application terminates with an error message provided by an exception.
After the library is successfully built and installed, it's header files are exported along with a cmake package.
Minimal example of CMakeLists.txt
to successfully link against library is:
One can run the binary directly from the docker e.g.
Note, that the binary docker image also have nginx
server installed hosting the documentation, e.g.:
as long as the docker is running the documentation will be available at http://localhost:8080.
Evaluation of stiffness()
method is limited by the stack. At present, at standard Linux configuration, it means maximal depth of the network should not exceed 50000. If processing larger network is needed, one can increase the stack size by:
Note that stack demands scale linearly with depth.
